Blow-thru e85 5.3 timing..........
Old Apr 14, 2016 | 07:01 PM
silverstreak98maro's Avatar
Default Blow-thru e85 5.3 timing..........
New to the whole e85 and blow-thru turbo setup and need some insight on this damn msd-6010 box and how to setup my timing curve for map and get this thing going. Details are as follows, 2005 5.3 with stage 2 cam, arp studs, ls9 gaskets, gt45 80/77 60a/r compressor 1.15a/r exhaust with t4 flange, non ic, quickfuel e85 carb 750cfm with 80 pri jets and 65pv, sec 91 jets n extensions and blocked pv, a1000 pump, and looking to run 15psi on the street and could really use some info on the timing on the msd box... Also using br7ef plugs gapped @25...... Th350 trans and 342 rear gears with 255/60/15 drag radials thanks in advance....
Old Apr 14, 2016 | 07:30 PM
Serioussn95's Avatar
I have a forged 370 blow thru intercooled s480 setup. With my 6010 im in the 30's like im NA until I hit atmosphere then I pull timing 1 degree per pound of boost. so on 10lbs im at like 15 degree using E85.
you say stage 2 cam. Whose cam?
Old Apr 14, 2016 | 07:52 PM
Not sure guy that built car b4 i obtained it to finish up said like 228/230 cam stage 2 lol so not sure really
