Boosted ring gaps
Old Jun 16, 2016 | 08:12 PM
  #41
sbcgenII's Avatar
Read the paper that comes with your rings and go with what the manufacturer says.
Old Jun 16, 2016 | 08:36 PM
  #42
MY_2K_Z's Avatar
Some of the people on this forum are completely worthless and unwilling to help and I really don't get why. Why bother posting if you don't want to help, were you just born knowing everything there is to know about building a motor... **** no someone helped you and taught you, you should do the same share what was taught to you to other people to make them more knowledgable.
And to the guy that said read the instructions that come with the rings. If your reusing stock rings there are no instructions.
Old Jun 16, 2016 | 10:30 PM
  #43
rotary1307cc's Avatar
Are you dense?
Old Jun 17, 2016 | 12:04 AM
  #44
MY_2K_Z's Avatar
Nope just really thought you could help. I've seen you're build, seems very well done and so I figured you must know your **** and could help us that are still learning.
Old Jun 17, 2016 | 07:44 AM
  #45
State the actual bore size you are working with and the actual ring. Stock?
Old Jun 17, 2016 | 09:27 AM
  #46
MY_2K_Z's Avatar
Cleaned up factory 3.78 bore with a hone and reusing factory rings
Old Jun 17, 2016 | 09:34 AM
  #47
Forcefed86's Avatar
Most of these questions have been answered many times over... even in this thread if you look.
Fuel used? boost/power level desired? SCR/DCR? RPM? IC? all those play a roll. Then there's the tune itself.
I've never butted an OEM ring with a .022 top ring on E85, intercooled, with water/meth on small bore stuff. Pinged 30lbs a few times too... Usually the ring gaps are around that anyway on a 100k+ mile motor. I've seen a few tight ones though.
As long as the bottom ring is .002 or so larger than the top, I don't mess with it.
Old Jun 17, 2016 | 11:02 AM
  #48
I'd be around 20 top, 18 second
Just because the second ring is tighter cold is far from the case in a running engine
Old Jun 17, 2016 | 11:22 AM
  #49
Forcefed86's Avatar
They are naturally looser on the second ring from the factory. I’ve never seen a bottom ring tighter than the top on a used LS and I’ve never seen a lower ring as tight as .018. I’ve opened up quite a few and were all right around .022 top and around .024 or so on the bottom ring. Some tops as tight as .016. Usually thrown in randomly with a bunch of .022 on the other pistons. Assuming they never seated properly on break in. Could have been a new piston/ring install, but didn’t look like it.
Old Jun 17, 2016 | 11:34 AM
  #50
MY_2K_Z's Avatar
And for further information it's a gen3 4.8 gen4 internals on e85 dual walbro 450s, 243 heads and probably 20-25 psi on kill and 15 otherwise. Factory ecu in a 2000 fbody with a 4l80e
Old Jun 17, 2016 | 11:38 AM
  #51
Forcefed86's Avatar
Check what they are at now... most likely they are fine if they fall within the ranges stated above. Clean out the carbon in the ring lands, and slap it back together.
Old Jun 17, 2016 | 12:30 PM
  #52
Taxman20's Avatar
Forcefed86 knows my setup, but for the others here its.
4.030 forged piston. New Steel rings. LQ4, 317 heads, dual 044 pumps to 80lb DEKA injectors. S482 turbo.
PSI is unknown right now. But I would assume about 7-9psi on the street and low 20's on the track. Pump gas for street, race gas if needed for track, A2W IC, Meth injected at higher boost levels when needed.
As for the gap, the bore doesn't seem to effect it a whole lot from the calculations. So the difference between a stock bore and .070 over less than .0005 at .006 per inch of bore. So its .024 with a 4" bore and .02442 on a 4.070 and with this I would just stay at .024
I actually told my machinist to be .026 top and .028 second. I am playing it safe. Its a race engine so I don't mind it being a little loose.
