anyone see an issue or have advice for this hotside?
Old May 2, 2016 | 05:53 PM
Schnitz's Avatar
Question anyone see an issue or have advice for this hotside?
This is my first diy turbo. I want to retain the sway bar so I have used these specific manifolds for this reason. I plan on using a 90 bend off the passenger manifold blended as nicely as I can to the vertical pipe.
Anyone see an issue with this?
I was thinking about 2 positions for the Wastegate. Either at the bottom 90 straight off the horizontal flex pipe portion or between the passenger side pipe and the turbo. Any advice is really appreciated.
Old May 2, 2016 | 06:57 PM
3 window's Avatar
Looks good. Put your wastegate on the merge right at the turbo angled towards to turbo if you can. That way it'll be fed by both banks. That's how I'd do it.
