N/A cam with a turbo?
Old May 12, 2016 | 05:29 PM
lkeller's Avatar
Default N/A cam with a turbo?
i originally was building a N/A 5.3 i got the texas speed 228r .600 lift 110lsa but now bought everything for a turbo build, and my question is how much will this cam hurt me?
Thanks in advance for the input
Old May 13, 2016 | 09:40 AM
JoeNova's Avatar
Restricted User
Depends on the turbo setup, top end power could start falling off very very early.
Old May 13, 2016 | 11:58 AM
drecpt83's Avatar
The only way you're going to know for sure is to try it ,other wise You could always sell/ trade it for something more "boost" oriented.
Old May 13, 2016 | 02:04 PM
NitroFumesAteMyBrain's Avatar
Buick GN cams were 107 lsa, take that for what u will. Will it make more power earlier with a wide turbo grind? Sure. If this is a racecar, change it, if its a street car, enjoy your choppy idle and turn the wastegate up another pound or two.
Old May 13, 2016 | 02:26 PM
JoeNova's Avatar
Restricted User
The stock GN cam might have been on a 107 LSA, but it still had -20 degrees of overlap @.050.
A TSP 228R on a 110 LSA has around 8 degrees of overlap. That is a significant difference.
Anything over 0 degrees increases the chances for reversion from exhaust pressure, which will make top-end power take a nose dive.
Old May 13, 2016 | 03:07 PM
Forcefed86's Avatar
Run a nice flowing set of twins that won't make any real back pressure and you'll be set. Otherwise change the cam.
Old May 13, 2016 | 04:45 PM
stevieturbo's Avatar
If you drop it on your toe it will hurt like ****.
Old May 13, 2016 | 06:00 PM
Nitroused383's Avatar
It will be fine just run it. My cam is on a 110 LSA with more overlap although it's not ideal it has no problem making HP.
Old May 14, 2016 | 03:48 PM
rpturbo's Avatar
I 100% agree for what that is worth. The lift and duration are decent overall, the overlap/layout of the cam is the issue. Ideally, less overlap is better, but I would have no issues running that cam!
