Help with Hobbs switch
Old May 14, 2016 | 09:13 PM
MeMz's Avatar
Default Help with Hobbs switch
I bought a Hotwire kit and dual in tank Walbro kit from show me speed and the Hobbs switch sold with the kit was discontinued so it's missing from my kit.
I'm really not understanding the threads about which switches I should be targeting so I would like help pointing me to the correct one....
Fuel system is dual Walbro 255 with Hotwire kit from showmespeed
80lb Siemens injectors on stock fuel rails
Want Hobbs switch that will kick on at 5 psi to complete my kit
Any help would be greatly appreciated!
Old May 14, 2016 | 11:02 PM
tennerv8's Avatar
I purchased a honeywell hobbs switch that comes on at 4psi. http://www.ebay.com/itm/NEW-Hobbs-Pr...UAAOSwSdZWceyS
Old May 15, 2016 | 06:05 AM
forcd ind's Avatar
I used the Honeywell also-some of them have a rubber plug you can rem. and tweak the screw to change the PSI range
Old Oct 18, 2016 | 07:22 PM
MeMz's Avatar
Bumping this thread again, need some help tracking something down. Thanks in advance !
Old Oct 18, 2016 | 07:25 PM
MeMz's Avatar
http://www.ebay.com/itm/0249-B76575-4-PSI-Hobbs-Pressure-Switch-P-N-76575-4/172366539308?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37115%26meid%3D5719f4687b9b427a9a39e7502a7ce576%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D162055217985
This the same thing? Similar part number, forgive my ignorance
Old Oct 19, 2016 | 10:34 AM
Black_Sunshine_99's Avatar
This is the one I bought, its set at 4 psi from the factory and works perfect.
Its also adjustable if need be.
http://www.ebay.com/itm/76575-4-One-...-/322120163854
Old Oct 19, 2016 | 01:04 PM
pdasterly's Avatar
is racetronix still sponser, i havent posted here in a long time
http://www.racetronix.biz/itemdesc.asp?ic=HPS-4&eq=&Tp=
