3bar map, help!
Old Jun 18, 2016 | 07:10 PM
blk99camaro's Avatar
Default 3bar map, help!
Posting for a friend:
I have a MSD 2313 three bar map sensor I put on my boosted LS1 Trans Am. I wired it per the factory pin out as follows. Blue 48 5v. Blue 54 sensor ground and red 32 sensor signal. I changed my tune file to 3 bar and I am getting a constant kpa value of 105. (Boost or vacuum) I am told that the Pcm needs repinned for a 3 bar map. Does anyone have that pin out info?
Jon
Old Jun 18, 2016 | 07:28 PM
sbcgenII's Avatar
You don't need to repin the ecm for a different map.
Old Jun 19, 2016 | 04:05 AM
stevieturbo's Avatar
And when you apply vac/pressure to the sensor, does the output voltage change ?
