D1SC 8 rib to 6 rib?
Old Jul 11, 2016 | 01:12 PM
Coda634's Avatar
Default D1SC 8 rib to 6 rib?
I know this sounds backwards, but I do not have enough clearance to run an 8 rib set up.
My car is a frankenstein build.
Vette accessories, low mount alternator,
Procharger had 8 rib bracket in the vette location but I need to shim it out for a 6 rib pulley since the belt is walking forward on the 8 rib.
Does anyone know if an offset 6 rib will space it out to the same place as the 8 rib, minus - ribs? Or what would be the distance of shimming to align the belt in place with the 6 rib brackets?
Old Jul 11, 2016 | 02:11 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The offset pulley is going to put it out too far for what you're doing. It sounds like you have a bracket alignment problem that needs to get worked out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
