lq4 turbo build (need help)
Old Jul 22, 2016 | 01:32 PM
2001camarolq4's Avatar
Default lq4 turbo build (need help)
I have a precision 76/75 t4 turbo sitting around and I want to finally do a turbo build I was wanting to go with an lq4 I need ideas of what all I need to buy and if anyone has a similar build if they could share what they have done or bought.
,Thank you.
Old Jul 22, 2016 | 01:55 PM
Black89Z51's Avatar
This has been covered hundreds of times. Try a search. Google Sloppy mechanics, sloppy wiki, etc.
Not to mention that is about as broad as a question can get and still have a complete thought.
Old Jul 22, 2016 | 03:21 PM
Drewstein's Avatar
Well the first thing you need is a car for the turbo. I suggest the classified section.
Then you'll need a motor and part for the turbo. There's plenty of vendors and a parts classified section.
After that you're set!
That answer is about as detailed as the question BTW.
Old Jul 22, 2016 | 04:52 PM
alocker's Avatar
Here's my build thread. Should cover everything and more.
https://ls1tech.com/forums/conversio...hp-17-psi.html
