CX racing GT45R Failure
Old Aug 20, 2016 | 10:18 PM
coltboostin's Avatar
Originally Posted by IH8FORD
Yup, thats a ball bearing.
carry on!
Old Aug 21, 2016 | 11:46 AM
IH8FORD's Avatar
i'd call cx and see what they say about restrictor sizing for this particular turbo
I talked to them, and the restrictor I was using is telhe right one. And said I only needed minimum of 7 psi of oil pressure at the turbo.
Old Jun 18, 2018 | 01:25 PM
JensenB's Avatar
Had to bring this thread back because I am going through the same exact issue. I have about 60 miles on my new cxracing 80mm and I couldn't get it to go into boost. It makes a noise like a bad tensioner bearing and then slows down. It was fine as it spools up then bogs right before boost. For oiling i have a hv/hp pump, .047" restrictor (they said run a 030 - 035) at idle w/o restrictor i can fill a cup with oil in around 25sec. Have freeflowing 7/8" drain to top front of pan. WORST PART is I called cxdicks and got hung up on soon as i said my turbo failed!
Old Jun 18, 2018 | 02:26 PM
JensenB's Avatar
Juts finished up my build in my cts V. Here's a link to my build
https://ls1tech.com/forums/forced-in...rbo-build.html
Have less than 100 miles on it and the turbo has taken a ****. It went to squalling and the best I can tell iy has locked up. Ill know tomorrow when I pull it. I've checked the oil feed and have oil going to the turbo. I run the restrictor that came with the turbo. I think its .035. Not sure what went wrong, I dont think it was the fault of the turbo, but maybe I didn't have enough oil flow. Any ideas?
I just tore it down and found the inner circlip holding the turbine bushing completely off! The journal bearing was moving around and binding up in there! Gaw dam chinese!
Old Jun 18, 2018 | 06:05 PM
customblackbird's Avatar
I ran the supplied restrictor on my 76/65 from CX and it’s journal bearing. Put on 500 miles or so with no issue. RunniNg a GMPP HV oil pump which is a stock LS6 pump and I only have 20psi hot oil pressure at idle.
I always thought that journal wanted no reatrictor and BB needed a restrictor.
The restrictor measured .035”. I just yanked the turbo and put in a VS cast 78/75 and drilled out the feed to 1/8” as VS says no reatrictor and mine is journal bearing again.
