Let's Talk about Check Valves....
Old Aug 23, 2016 | 12:53 PM
Hardcoresoldier's Avatar
Default Let's Talk about Check Valves....
So, as you know I am going twin turbo. I plan to run a vacuum hose from the brake booster port on the intake to a vacuum block, then run all of the vacuum lines from there - including the brake booster. I hear some say yes you need check valves, and some say you don't.
Do I actually need check valves? If so, where?
Old Aug 23, 2016 | 01:00 PM
svslow's Avatar
The brake boost on my car, which was turbo from the factory, has a check valve on it. It is essentially a PCV valve.
JoeNova's Avatar
Restricted User
The fitting that goes on the end of the hose and presses into the brake booster IS a check valve.
Old Aug 23, 2016 | 02:30 PM
cajundragger's Avatar
yep- the fitting in the diaphragm is a check.
I do run a check instead of a PCV though.
since I am having a single vacuum hose going to the vacuum block (then everything vacuum related going from there) should I place a check valve between the intake and the vacuum block?
Old Aug 23, 2016 | 02:34 PM
MY_2K_Z's Avatar
No because then your waste gate would never see positive pressure
Old Aug 23, 2016 | 03:23 PM
oscs's Avatar
My booster did not come with one. I ran a check valve inline to the booster only.
Old Aug 23, 2016 | 03:47 PM
the blend doors on my HVAC are vacuum operated. would all that positive pressure screw them up or should I put a check valve on just that?
Old Aug 23, 2016 | 03:49 PM
forcd ind's Avatar
I run a ck valve, and oil sep, but only go from intake to PCV valve
Old Aug 24, 2016 | 07:33 AM
Bad Apache's Avatar
I'd consider splitting the vacuum system up. The HVAC needs a check valve, unless you like it switching to the defroster ducts every time you get under a load. There is a GM model (I want to say S10 or maybe Trailblazer, help me here guys) with a check valve on the brake booster that has a port for the HVAC. If you have cruise control, you also will want to check valve that. The others could be run off a good vacuum tree.
Old Aug 24, 2016 | 01:02 PM
not worried about cruise control, I am DBW. I was also told today that my HVAC already has a check valve in it so it looks like I won't need to add any.
