Microsquirt Boost controller for noob
Old Aug 23, 2016 | 06:32 PM
C10Lm7's Avatar
Default Microsquirt Boost controller for noob
Can someone expalin how I can wire and set up an EBC solenoid to my microsquirt? I am shooting for 5psi to start off with.
Old Aug 23, 2016 | 08:15 PM
yenkomike's Avatar
there is an old thread on it but I think you run power to the solenoid and the micro is a ground signal .
Old Aug 23, 2016 | 08:18 PM
Dave926's Avatar
Switched 12v on one side, Micro on the the other.
Can't run less than WG pressure
Old Aug 23, 2016 | 09:20 PM
C10Lm7's Avatar
How do I set max boost? How do I set up the boost duty table too?
Old Aug 23, 2016 | 10:19 PM
Dave926's Avatar
I would suggest sticking to open loop.
Set the duty table to 10% @100% tps and see how your boost reacts.
I would also suggest setting overboost protection in case something isnt right
Old Aug 24, 2016 | 09:30 AM
svslow's Avatar
Wiring is as mentioned above, one side of the solenoid gets 12V and the other goes to FIDLE at the Micro. You will have to create the boost duty table of TPS vs Boost duty. Depending on how the solenoid is wired and the output polarity 0% boost duty could be wastegate pressure or 100% is wastegate pressure. Just set it up one way and see what happens so you know what to change.
