Compression ration assistance, please?
Old Sep 15, 2016 | 08:30 AM
Mike Cordero's Avatar
Default Compression ration assistance, please?
I have a 6.0L iron block, bored to .030 with a 4" crankshaft and 6.125 rods, the pistons is a -29 cc one (JE). My questions is: what's the CR if I use the mentioned combination with a 243's head with 64cc chamber and if I use a 317's with 72cc chambers? I'm planning to go twin turbo. Also can use a standard stroke crank with the 6.125 rods and flat pistons (Diamobs-3cc's); by using the same heads, what would be the CR and which combination would be better for the TT combo?
Old Sep 15, 2016 | 04:05 PM
stevieturbo's Avatar
http://www.csgnetwork.com/compcalc.html
Old Sep 17, 2016 | 02:25 PM
I'm only looking for an estimate. I don't know about numbers, just what I wrote at the beginning of the post; no idea of gaskets gross/thickness or other number to calculate. Can you do some numbers???
Old Sep 17, 2016 | 10:02 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If YOU don't know what you are using to build the motor, how can anyone else give useful info?
Old Sep 18, 2016 | 02:53 PM
bwolfZ28's Avatar
With those je pistons and using ls9 gasket with a compressed thicknss of .051 and assuming the pistion will be .007 out of the hole. If you have stock deck 243 heads your compression ratio will be ~8.9:1. if you mill the heads .006" for every 1cc of volume and you mill them down to say 61cc your compression ratio will be ~9.1:1
Old Sep 18, 2016 | 02:55 PM
bwolfZ28's Avatar
keep in mind those above numbers are for a 4.00" stroke crank.
