LS9 MAP Sensor on 0411 ECM
Old Sep 27, 2016 | 09:59 AM
rworcester's Avatar
Default LS9 MAP Sensor on 0411 ECM
I'm using the ZR1 LS9 MAP Sensor from GM p/n 12592525 so that I can utilize boost up to ~30 psi if needed. However, It looks like the plug is different than my wiring harness MAP plug. I see that Lingenfelter offers this http://www.lingenfelter.com/product/CE105208.html but it lists the conversion from LS3 to LS1. Is the LS3 MAP Sensor the same plug as the LS3? Or is there another adaptor out there for the LS9 3 bar MAP sensors?
Old Sep 27, 2016 | 10:04 AM
bigmandengo's Avatar
LS9 and LS3 should have the same plug for a bosch sensor.
Old Sep 27, 2016 | 10:11 AM
rworcester's Avatar
Sounds good, thanks
