Boost solenoid questions for rook!
Old Oct 6, 2016 | 03:38 PM
sti lol's Avatar
Default Boost solenoid questions for rook!
I have a holly efi plug and play on my lq4 with a 80mm comp turbo and meth, built top stock bottom end. In a fox so I'm gunna need some taper to use any power on the street. Now... question time. Holly sells 3 port solenoids that have clips for the efi ecu, I'm running 2 38mm wastegates. 2 wg's possible with a 3 port or need a 4 in which case holly no longer sells. Maybe twin 3 ports now I'm using up serious connector real estate. Anyone here done something with 2 wg's wanting street ability with solenoid (s)
Old Oct 6, 2016 | 05:50 PM
93camaro_zzz's Avatar
You can use twin 3 port solenoids. Check out page 44 on this document:
http://documents.holley.com/199r10628rev2.pdf
Old Oct 7, 2016 | 05:08 PM
sti lol's Avatar
Thanks, I've read through a lot of that holly book. That shows 2 3ports and one wastegate.. I'mpoking at 2 38mm wastegates and how to set up solenoids... i may change plans to a single 60 making this all easier.
Old Oct 8, 2016 | 09:26 AM
You can use the above setup for twin gates, just try to make the split to both gates as far away from the solenoids as you can. Then it will work just fine.
