IAT "anti-lag" switch, looking for pointers, HPTuners user.
Old Feb 7, 2018 | 06:50 AM
JoeNova's Avatar
Restricted User
Originally Posted by LQ4-E39
bump. I am looking to do something similar on my 2000 C5, retard timing when the IAT goes to 14F, which is the lowest temp available on the table "IAT Spark Advance Correction".
I want to do it a bit differently and try to use the clutch to trigger the IAT cut using a relay - anyone ever done that before? (This would be used in conjunction with the No Lift Shift setting of an N2MB Wot box)
It doesn't matter how you activate the relay, as long as you activate it. You could wire it to a dome light button if you wanted to. Its irrelevant.
Old Feb 7, 2018 | 07:37 AM
LQ4-E39's Avatar
Yup, I follow you - I just wonder if the clutch switch is an interrupted 12V signal, or interrupted ground or whatever. I suck at wiring/electricithingamajigs.
Old Feb 7, 2018 | 09:11 AM
JoeNova's Avatar
Restricted User
Start looking through newspaper/catalogs/magazines. Harbor Freight is giving out free digital multimeters in this months coupons.
Old Feb 7, 2018 | 09:38 AM
LQ4-E39's Avatar
I ain't that bad - thinned out a Van Harness and built a harness from scratch for my old BMW, keeping the gauges working and etc back in the day. Just takes me a hell of a lot longer!
Old Feb 7, 2018 | 10:13 AM
dmaxs10's Avatar
Hey joenova how did the boost by gear work with stock ecu?
Old Feb 7, 2018 | 02:05 PM
LQ4-E39's Avatar
Found a helpful link on the sloppy page. That place is awesome...
http://sloppymechanics.freeforums.ne...-antilag-setup
Old Feb 7, 2018 | 02:22 PM
truckdoug's Avatar
Yeah I spend more and more time there. Lots of good low buck diy solutions.
