LSA Blower and Turbo?!
Old Nov 7, 2016 | 06:21 PM
1999Firehawkls7's Avatar
Default LSA Blower and Turbo?!
Wondering if the blower would become a restriction or if this would hammer on the blower to hard......
It would be sweet to have the best of both worlds!
Old Nov 7, 2016 | 11:58 PM
FourG63 97GST's Avatar
theoretically it will become the restriction, but depending on your power goals, the restriction will be irrelevant and it can work well for you
Old Nov 8, 2016 | 12:38 AM
1,000-1,200 whp
Yes I know you can get this w one correct Turbo but having the low end trq from the blower I think would be sick
Old Nov 8, 2016 | 06:56 AM
JoeNova's Avatar
Restricted User
Very bad idea for that power level.
Old Nov 8, 2016 | 12:39 PM
Project GatTagO's Avatar
Seemed to work for this guy...although that quite at that power level...
https://ls1tech.com/forums/conversio...onversion.html
Andrew
Old Nov 8, 2016 | 01:09 PM
JoeNova's Avatar
Restricted User
Andrew
It can definitely work well.
The problem is efficiency. If he removed the blower and ran those turbos at the same 26 PSI, he would likely lose power below ~2300 RPM but gain another 150+ HP up top. You're trading overall efficiency for low end power. A compromise you have to understand. His engine is probably seeing the stress of an engine with another 150 HP as well.
And there is the heat to deal with. He's running two intercoolers and a heat exchanger. If you can get over all of the hurdles, you'll have a fun ride.
