Twin ebay turbos
They flow more than the typical t3 ebay stuff by far. Also loud (and likely laggy) by comparison to a gt35... but will make more power per pound and are internally gated. If you look around you can find some that I'm told have a true 60+mm compressor. Usually labeled as "super drag" like this...
I’ve never ordered one and going by the picture I’d guess they are the typical 54mm and the guys don’t know how to measure it correctly. U can always return it though if it’s not a true 60mm since the AD claims it is. Might want to ask the seller first before purchasing. I did and they claimed “it’s a new more bigger wheel for performances”. So…
http://www.ebay.com/itm/Dodge-Ram-Di...dVu-YE&vxp=mtr
Thats a good find, I would love to be able to find a single that was big enough for a mild 4.8/5.3 build that has a internal gate..... makes the install much cleaner. Now if someone would just knock off the EFR's with the built in BOV we would be set.
Edit..... I see this lists a bigger compressor wheel
http://www.ebay.com/itm/91-04-Freigh...FSDnLr&vxp=mtr
http://www.on3performance.com/shop/o...-turbocharger/
http://www.ebay.com/itm/GT35-GT3582-...RXB1m~&vxp=mtr
I also wanted the ball bearing deal too. I just saw where CX is offering my same turbo with a T6 exhaust now, and the also have the GTXish 11 blade 80mm compressor wheel avail for the same unit.
VS came out with the 77/83 and 88/83 about a month after I bought the CX 80/77.5. I would have looked at them hard, if they had been out there.
