LY6 On3 Turbo Question!
You can run high compression with a turbo, you just need to give it appropriate fuel. I know that in some of the race classes that limit turbo size, they use very high compression engines. That's because the only way to gain more power, is to gain efficiency, because airflow is limited by the best compressor wheel you can get, and still meet class rules. Even if you don't go E85 or meth, you will need to pull timing out of it and run the best fuel you can find, 93 octane or such, and you will be boost limited by knock. However you can still have a wicked gain before you hit this limit, probably a couple hundred HP.
