Foxbody turbo
Old Dec 12, 2016 | 12:30 PM
sbf's Avatar
sbf
Default Foxbody turbo
Does any company sell the turbo kit for a foxbody mustang
Old Dec 12, 2016 | 01:00 PM
svslow's Avatar
https://ls1tech.com/forums/conversio...kit-build.html
Old Dec 12, 2016 | 01:35 PM
boostedstang's Avatar
CXRACING makes them to.not sure I've heard bad and good on both kits looking to buy or build me one to for my lsx foxbody.I found one
JGS 60mm waste gate
JGS 50mm discharge valve
Borg Warner S475 T4
Hotside is all tig welded MS, all coated.
Down pipe is 409 SS, also coated with O2 bung 12" from the outlet. Exits at the pass side front lower fender.
Cold side is all v banded minus the turbo outlet and hat inlet. If you're running an EFI setup you'll need to make a small change to the last section of charge pipe to meet your TB.
This will come as pictured, ready to install and connect to your blow thru carb. Kit might have 100 miles and 10 street hits for 1600.Ive got a 6.0 with edelbrock pro x intake and 317 ported heads with stage 2 lmj cam and power glide not sure how this would work on my setup
Old Dec 12, 2016 | 01:56 PM
svslow's Avatar
You could buy a mig welder and some tubing for less than what a kit will cost you.
Old Dec 15, 2016 | 01:24 PM
2002camaroSS's Avatar
Huron speed was working on one to sell for a ls swapped fox body
Old Dec 15, 2016 | 09:05 PM
Longblue's Avatar
B and G turbo. Makes an LS swapped Mustang kit.
