Huron V2 A/c kit
Old Dec 13, 2016 | 05:36 PM
Tom Curtis's Avatar
Default Huron V2 A/c kit
The guys running this kit what are you using for a radiator hold down?
Old Dec 14, 2016 | 04:04 PM
Black_Sunshine_99's Avatar
This is what I used with my Huron V1 AC kit and TC7868 turbo.
I drilled new holes in it and pulled the radiator farther forward for my T7875 though.
https://www.summitracing.com/parts/b...mAQaAnUE8P8HAQ
Old Dec 14, 2016 | 04:30 PM
necrocannibal's Avatar
Any pics of it installed? I have been looking for something like this to fix how mine is done.
Old Dec 14, 2016 | 07:17 PM
JMD759's Avatar
I have mine on a 95 camaro. I used the stock radiator cover/holder without issue. I elongated the bolt holes a little to pull the radiator/fans closer to the radiator support to hold my fans. I have seen pics of guys using a 2 small (1") wide pieces of metal and just cut/bend/ and secure the radiator to the support.
Old Dec 15, 2016 | 07:06 PM
I had to pull the radiator forward a few inches to clear the larger T7875 turbo I installed but this worked very well, it was chrome but I picked it up with the carbon fiber wrap.
Old Dec 16, 2016 | 10:16 AM
Superman09's Avatar
LS1Tech Sponsor
I really like using this piece from BMR, looks awesome!
http://bmrsuspension.com/?page=produ...285&superpro=0
You can also use a standard radiator hold down from a LT1 car as they do not have the airbox built in. Additionally you could still use your OEM, just looks a little goofy with no filter in there...
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
