Snow Performance PushLoc Leaking
Old Dec 19, 2016 | 01:41 PM
96redcamaro's Avatar
Default Snow Performance PushLoc Leaking
I have a snow performance meth container that i cannot get to quit leaking out of the bottom PushLoc. Anybody ever have this issue before?
Old Dec 19, 2016 | 02:03 PM
svslow's Avatar
Is the bulk head fitting leaking or the actual push lock where the hose goes in?
Old Dec 19, 2016 | 11:11 PM
I'm pretty sure The actual pushlock is leaking
Old Dec 20, 2016 | 09:28 AM
customblackbird's Avatar
Have you cut the hose perfectly straight with a razor on a hard flat surface? You what the cut straight and flat 90*.
Also if you have removed it more than a few times it will leak... just cut a smidge off and insert back.
No problem with mine and its like 5 years old.
Old Dec 20, 2016 | 09:42 AM
Photochop's Avatar
I had a pushlock fitting leaking recently, no matter what I did it wouldnt stop. It was at the pump, you can get a replacement fitting from them or from Devil's Own (local to me). Same part, just make sure you get the correct size for your application.
Old Dec 20, 2016 | 10:23 AM
dburt86's Avatar
Exactly this. Take it, cut the hose perfectly straight. Use a sawing motion to avoid pressing down and ovalizing the tube.
Old Dec 22, 2016 | 03:34 PM
I took the hose off and cut it as straight as possible with a razor on a table, and drove it around the block. So far it hasn't leaked anymore. Hopefully that was it.
Thanks
Old Dec 22, 2016 | 04:33 PM
Detoxx03's Avatar
The snow kits always leak. Had four friends with those kits ditch them for alky control and their stainless lines.
 Michael S. Palmer
Old Dec 22, 2016 | 06:27 PM
stevieturbo's Avatar
All those pushlok's will leak eventually. Sometimes it will be the fitting itself, others the hose squeezes up a little and needs that bit cut off.
