Turbo iron ls1 with (with AC)
Old Dec 21, 2016 | 11:32 PM
Tlwest's Avatar
Default Turbo iron ls1 with (with AC)
I have a 2001 blazer xtreme. Im building an iron ls1and going to turbo it. Parts list so far
Tahoe 5.3 with 862 heads $200
58x crank wire harness and ecm $250
Hardened pushrods $100
Schd 10 SS piping $250
AEM wide band & Truboost
Things left to get:
Forged pistons
On3 turbo
Wastegate & blow off valve
Intercooler
TSP cam kit
4l80E
Anyways heres some pics of current progress
Attached Thumbnails Turbo iron ls1 with (with AC)-1016161926.jpg   Turbo iron ls1 with (with AC)-1221162140a.jpg
Old Dec 22, 2016 | 03:35 PM
Black_Sunshine_99's Avatar
Skip the forged pistons and use a LJMS Stage 1 or 2 turbo cam.
Old Dec 22, 2016 | 04:29 PM
323z's Avatar
Any mods to the frame?, seems like a weak point on these blazers/s10's.
I am nitpicking but is there such a thing as a iron ls1?. Wouldn't it be easier to just call it a 5.3 or LM7.
Old Dec 27, 2016 | 12:42 AM
Tlwest's Avatar
I havent done anything to the frame to strengthen it. I did notch it for the AC to stay in the stock position.
I could call it a 5.3 LM7 but after bore it will be a 5.7. It will slightly resemble a 5.3 because I still have truck intake and accessories on it. But internally it will be a LS1.
Old Jan 7, 2017 | 10:59 PM
Tlwest's Avatar
Did some more work on the manifolds today. Its my first time doing pie cuts. I could have just ordered a 90 degree but I wanted to work on my welding and fab skillsand this was the excuse.
also got in a double walbro setup and some forged je pistons. Going to the machine shop next week to balance the rotating assembly. If i balance the assembly with the 4l60e flywheel will it be a problem when I change to a 4l80e and have to get a different flywheel?
Old Jan 8, 2017 | 09:42 PM
Tlwest's Avatar
Got the driver side to fit around the stock steering shaft. I will probably work in the steering shaft mod to get some more space. Fab skills are getting better. I will probably clean the cuts up so it welds nicely. But progress is coming. Driver side log and stock steering shaft
