Turbo boost
Old Dec 25, 2016 | 10:05 PM
Mlovett's Avatar
Default Turbo boost
Have a stock 5.3 with twin 62 mm turbos and Im at 11 lbs of boost, was wondering how much boost a 5.3 will handle. I'm really new to turbos.
Old Dec 26, 2016 | 12:20 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If this is a serious question, then you are in for a lot more reading. If this is a case of internet trolling, the go **** yourself.
Old Dec 26, 2016 | 09:06 AM
truckdoug's Avatar
i know of one forum member here, who has put 30+psi into his 5.3
but it's really more about having the tune dialed and the fuel system well-sussed than it is about max boost pressure
i'm sure at some point you'll push water and have to add studs...but i dont know where that line is.
