Meth with a pd blower
Old Dec 26, 2016 | 05:49 AM
jimmyg's Avatar
Default Meth with a pd blower
I just bought the snow stage 2 kit for my whipple 2.9/ ly6 . I'm looking for some insight on how to set this up. I was thinking pre blower, but @ what boost # should it turn on ? Boost is pretty much instant .
Old Dec 26, 2016 | 08:17 AM
NitrOmm's Avatar
On my mini blower (MP112) I ran the meth/H2o pre blower.
Progressive system turned on at 4lbs. & quickly ramped up to 100% by 8 lbs.
the only consideration here is that you will enevitably saturate your IAT sensor. Your IAT readings will be skued due to this factor. If you are able to monitor EGT instead you can truly monitor the benefits.
Old Dec 26, 2016 | 02:42 PM
Jimbo1367's Avatar
Contact SNOW and ask them.
Old Dec 26, 2016 | 03:56 PM
jimmyg's Avatar
Well my iat sensor is in the bottom of the intake , so I don't really see that being a problem? So I guess I'm going to try start @ 3 psi and all in @ 10 . The kit I bought has the new boost gauge/ progressive controller. Vc-50. So @ 3lbs it will start spraying 10% and ramp up from there according to the directions.
Old Dec 27, 2016 | 11:20 AM
Realcanuk's Avatar
With a PD blower you are better to control the meth progression off airflow, rather than boost. Pretty sure Snow stage 2 allows for this.
Old Dec 27, 2016 | 12:56 PM
jimmyg's Avatar
Car is speed density tuned . Snow controller has a built in map sensor
