Log manifold - tube sizing I'm in the beginning stages of putting together a log manifold for a single T4 turbo 5.3 build. I work for a tube fabrication company so I have just about every tube/pipe size option at my disposal. My intention is to design a simple passenger side log that fits the fox chassis with an AJE k-member, because it's what I have to work with now. So the questions I have now are what ID tube or pipe is preferred? Has there been any testing done that supports a certain size? 3" OD is the largest I'd consider since I'm running a T4. I'm thinking something between 2.5" ID and 2.875" ID but honestly, I'm just guessing at it. Fortunately I have several options in this range. Anyone have any knowledge of log manifold design they'd like to share? Any input is appreciated. |
Holley has a new cast log coming out that will fit the Fox body chassis...just saying... Andrew |
Yeah, I'm aware of it but I'd rather have something cool to look at, like a fabricated stainless piece. |
personally i'd go with the .125 wall since that'll fit up to a t4 flange pretty nice. post pics as you make it plz |
factory truck manifolds have been 200mph in the 1/4 on a 3500lb drag LSx turbo Fbody..... If you can get past their looks.... they work! |
Here's a thread on it. https://ls1tech.com/forums/forced-in...manifolds.html |
Pass thru log on one bank or two individuals that mere at the turbo. |
Originally Posted by RealQuick
(Post 19502612)
© 2024 MH Sub I, LLC dba Internet Brands
