Making "log" turbo manifolds
Old Nov 5, 2012 | 02:55 PM
357i's Avatar
Default Making "log" turbo manifolds
I have done a pile of searches with no real info. I plan to make a couple log style manifolds for my turbo project. I am not doing truck manifolds because I want to keep the A/C. I will be using 304 stainless and I'm interested in some input on sizes. I'm guessing 1 5/8 primaries, but not sure of what thickness. All for primaries will run into a single tube(the log) and I'm unsure of the size and thickness that should be, maybe 2 1/8 or 1/4? I plan to have the turbo supported to keep the stress off of the manifolds and pipes.
So far, I'm planning to get everything from these guys:
http://www.stainlessheaders.com/index.aspx
Any input, links or pics would be appreciated.
Old Nov 5, 2012 | 03:55 PM
MUSTANGBRKR02's Avatar
Modify stock manifolds to a log style.
Old Nov 5, 2012 | 04:32 PM
shawnc16's Avatar
Built these. 1 1/2" sch. 10 elbows with 2" sch. 10 logs. The pipe I bought from ace stainless.
Old Nov 5, 2012 | 05:36 PM
2QWK4RU 06 GOAT's Avatar
Very nice.
Old Nov 5, 2012 | 05:50 PM
87silverbullet's Avatar
Why not a c6 manifold on the passenger side?
Don't have to build nothing but a crossover and still keep the A/C/
Old Nov 5, 2012 | 06:27 PM
dmaxvaz's Avatar
Nice! Shawn, send me a link where you bought those flanges again.
Old Nov 5, 2012 | 07:10 PM
shawnc16's Avatar
http://www.extremeperformance1.com/chevy-ls-c-85
Also would like to note the 2" pipe fits perfectly (butt welded) with 2.25" v bands.
Old Nov 5, 2012 | 07:24 PM
LSXS10's Avatar
How well do the logs work compared to stock manifolds or headers?
Old Nov 5, 2012 | 08:35 PM
427's Avatar
427
Very cool!
Kurt
Old Nov 6, 2012 | 09:01 AM
357i's Avatar
This is exactly what I am looking to do.
you got the 1/2" thick 1.75 flange? Seems like a pile of gap to fill with the 1.5" primaries. Did you weld inside and out on the primaries?
thanks
Old Nov 6, 2012 | 09:50 AM
shawnc16's Avatar
The fit isn't perfect but it's not bad. ID of the 1.5" pipe is actually more like 1 5/8. We did outside because the manifold was bolted to the head to minimize warpage.
Old Nov 6, 2012 | 10:46 AM
357i's Avatar
The 1.5 stuff on ace's website were all 1.5 OD and 1.37 ID Am I looking in the wrong place?
LilJohn's Avatar
The sizing on those weld els is decieving.
Its 1.5 inch Nominal.
The ID is actually 1.600.... almost 1 5/8's.
The od is 1.830-1.850. The flanges ive seen set up for a 1 7/8's pipe allow the weld el to fit inside the flange against the face of the head almost. It ***** it just a touch. I backed them up till the end of the pipe was square to the flange and had them welded on both sides of the flange and the surfaced.
I like how you fed that end cylinder into the log shawn... great job on those.
Edit:
The dimensions stated above are only for the schedule 10 stuff.
Old Nov 6, 2012 | 01:39 PM
ls1_chevelle's Avatar
Heres mine, been on the car for 3 years now. Changed the wg line a bit, just orientation wise.
Old Nov 6, 2012 | 01:57 PM
shawnc16's Avatar
Thanks guys. Gotta wait til next season to see how they perform.
Old Nov 21, 2012 | 07:05 PM
BOOST FREAK's Avatar
looks good.
Old Nov 22, 2012 | 12:32 AM
Haddixj's Avatar
curious on where you guys found 2.25 v bands?
Old Nov 22, 2012 | 09:09 AM
tta656's Avatar
pic of the C6 manifold please
