My TVS catch can routing
I had oil blowing out of the rear main seal under boost all over the exhaust the way it was routed before by a performance shop.
I ended up going with a 3 port can
- 3 port mishimoto catch can( 2in 1 out )
- each valve cover to the IN ports of the catch can
- OUT port on the catch can to the vacuum on front of blower.
- I do NOT have a vacuum port on my valley cover
This keeps the crankcase pretty under vacuum even when in boost
No more leak under boost, and the catch can has collected a very small amount of oil
the blowers depending on how tiny an air filter (or dirty as they clog quickly) can make a ton of vac, which is good for crank pressure but bad for hp (losing boost), so always a good idea to double check that.
it will probably not collect as fast as it used to since you are no longer running a pcv system.
i need to bring one of those in to test.
Exactly 8.5~8.7psi in hp tuners
and no more oil leaks so it's good in my book and meets my standards
you may notice that your oil becomes dirty quicker, so is good to keep an eye out for that vs. if you were doing a standard change interval with the pcv system functioning
