Help a newb!
Old Feb 8, 2017 | 05:03 PM
GO Dutch!'s Avatar
Default Help a newb!
While I have been drag racing big inch big block chevys with carbs for a long time, I have decided on my first LSx EFI build. It is going to be a LS3 based 427 with good heads, sheet metal intake big cam etc. What I am wondering is what AR the hotside of twin 76mm turbos should be. I was thinking .81 for quick spool, but may be smallish?? It will go in a 26-2700 lb drag "street" car.
Old Feb 8, 2017 | 10:48 PM
sschoeffler's Avatar
Turbos don't need big cams. 76mm turbos with a .81ar would match it nicely. That's a lot of power in a super light car. Should be fun if you can get it to hook up.
Old Feb 8, 2017 | 10:53 PM
ScottyBG's Avatar
What 76mm turbos are you planning on running, a S476 for example would be completely different than running Chinese 7665. The AR in my opinion is just fine tuning the combination, it is important, but not nearly as important as other things like compression, cam selection, and the actual turbo your going to run. Picking the size of the turbine, IMO is more important than the AR of the housing.
Old Feb 9, 2017 | 10:17 AM
GO Dutch!'s Avatar
Do not have the turbos picked out yet, and I do not have the cam picked out yet either, I will let one of the cam gurus on here help me with a cam, but with my heads still flowing 377 and 260 @ .700 lift, I figure a high lift cam would only help make some serious power. Hoping to get to 1500hp keeping the boost under 20 pounds. It will go into a fox body mustang coupe, and in all reality, I hope to get it down to around 2500 with this all aluminum motor. Fingers crossed.
Old Feb 9, 2017 | 10:41 AM
ScottyBG's Avatar
I'm not sure keeping it under 20lbs really helps you? You can easily build the engine capable of taking more boost than that. I think you would be better to make your power with more boost, and keep the cam profile less aggressive to do so. That way you will have a flatter torque curve. I think most cars making that kind of power are using more than 20lbs of boost. The few I've seen X275 cars ran more like 30psi. If you look at your compressor map, most modern compressor wheels are more efficient at 30psi than they are at 20. The low boost on large displacement engines tends to drive you off the right side of the compressor map. You really need to use a compressor map to choose your turbos. You may have some interest using match bot. Just google Borg Warner Match Bot.
Old Feb 9, 2017 | 10:49 AM
GO Dutch!'s Avatar
The thought was to make as much power as possible before boost, and then keep the boost on the lower side to keep from stressing parts, especially the stock LS3 block. If I can get to 1500 at 20# then if need be I can use 25-30# in an "emergency" situation LOL. I will check out the maps, like I said, I am a newb at this stuff, but I am smart enough to see the incredible power potential of the LSX engine!
Old Feb 9, 2017 | 10:52 AM
JoeNova's Avatar
Restricted User
427 in an LS3 block at 1500 HP? Let us know how that goes.
Boost is irrelevant. Run as much as you need to hit your goals. Your engine doesn't care about boost, only HP/TQ/RPM.
Old Feb 9, 2017 | 10:55 AM
GO Dutch!'s Avatar
Seems possible to me?? No?
Old Feb 9, 2017 | 11:56 AM
408GT's Avatar
It's possible, just won't do it for long.
Old Feb 9, 2017 | 12:00 PM
GO Dutch!'s Avatar
Only need it for 7.8 seconds at a time! LOL! But seriously, what would be the problem with this combo? Its already in the works...all these stock 5.3 build ups making 12-1300hp, I figured a forged 427 should be good for 1500hp easily??
Old Feb 9, 2017 | 12:03 PM
MY_2K_Z's Avatar
That factory block will start having issues at 1000+. Do some searching around. Walking mains, lifting heads, and many other issues. Lots of people come through here wanting 1500hp on a factory block but it's just not a good idea.
Old Feb 9, 2017 | 12:12 PM
JoeNova's Avatar
Restricted User
The 5.3 cylinders are MUCH thicker than the LS3 liners to begin with, and then you're boring them out even further. Then on top of that, you're increasing stroke, which will force the piston skirts into those already thin cylinder walls much harder than a stock stroke setup.
Recipe for disaster. If you want a 1500 HP 427, you're going to want an aftermarket block. The guys making ~1200+ on 5.3s do so because of the thick cylinder sleeves and shorter stroke doesn't stress the block nearly as much.
Old Feb 9, 2017 | 12:19 PM
GO Dutch!'s Avatar
I hear you, It will only be a .005 hone, And I am not dead set on making 1500, just thought it should be fairly easy to get there, that's why I was looking to keep the boost a little lower. Maybe I should just spray it... Damn turbos make too much power.
Old Feb 9, 2017 | 12:32 PM
MY_2K_Z's Avatar
Since this is your first ls why don't you keep it simple and do a stock cube build and keep it down around 8-900. If you need more build an lsx block.
Old Feb 9, 2017 | 12:35 PM
JoeNova's Avatar
Restricted User
People get hung up on boost. If you make 1500 HP on 50 lbs or 1500 HP on 5 lbs, your engine sees the same amount of stress. Sure, there are downsides to running a lot of boost, but don't think too much into it. Probably the highest HP stock shortblock ever was an aluminum 5.3 running 40 PSI through a billet 88mm turbo.
Boost it to your goals.
Old Feb 9, 2017 | 12:37 PM
JoeNova's Avatar
Restricted User
Oh and it will NOT take 1500 HP to run a 7.8 in a 2600 HP car lol.
Old Feb 9, 2017 | 12:41 PM
GO Dutch!'s Avatar
Well I am still tempted to try it! I assume someone on here must have tried it and failed, I would like to hear the horror stories. The build is an LS3 block .005 over with 4.100 crank. Are we assuming it won't work, or do we know for a fact it's a time bomb? I figure in N/A form it should make at least 650hp, so it would only take 10 lbs.or so to get it to 1000 or so, right?
Old Feb 9, 2017 | 12:43 PM
MY_2K_Z's Avatar
Go for it man. You don't seem to wanna follow anyone's advise so why are you here.
GO Dutch!'s Avatar
Yeah, Joe, thats the goal, and it could be done with less hp, just speculating...
Old Feb 9, 2017 | 12:49 PM
GO Dutch!'s Avatar
2K Z it is not that I don't want to take anyone's advice, I have this engine build in the works and want to try it. If I am going to drive over my crank at 150 mph I am not going to do it...if it will only last one season before it wears out, I may try it. I am asking the experts, and I figure the best person to ask would be someone who tried it. that is why I am on here.
