How far can I take E70 fuel?
Here is my timing map. It is aggressive, but there in no knock data logged on it on the Dyno. I'm running the BR7EF at 0.028. I'll continue to check #7 plug regularly, but for now it is looking good. I actually never thought I'd get that much timing in it.
This it the dyno graph on the 5.7 LS1, A4 with the converter unlocked, through the muffler, using that timing map, and E70. It makes about 60 more HP with the converter locked, but I only have a single disk, so I don't normally lock it while tuning just to get a number. It would be in the 775 range locked. It was still making more power when I let out of it at a little over 6600. This is setup like my signature says.
If you can put the nozzle down lower towards the outlet of the intercooler that'll work to, heat also rises so the fluid stays cooler also if you get a fire having it down low keeps it out of the flames longer. It also hides it from view and looks cleaner.
Also seen base timing off as much as 2*... so a commanded 18* might be 20* on your setup and 16* on someone else's. Plugs won't lie start low and work your way up...
As far as reading plugs for timing, I am guessing you're reading the strap. Have you found that you can read the straps of the plugs you drive around with on the street (after a pull or two and drive home), or do they need to be fresh plugs with a sharp cut after a pull like reading mixture?
