2nd Pump Questions
Old Feb 13, 2017 | 01:19 PM
RonSSNova's Avatar
Default 2nd Pump Questions
I noted in my logs last year that the fuel pressure quit tracking with boost past 5000 rpm when I turned the boost to 19 psi.
AFR was fine, but it's a sign.....
So I'm adding a second pump on a pressure switch.
The question I have is do you see a spike in FP when the second pump comes on?
You guys turn it in early? Or just ahead of where you start seeing the fuel pressure fall?
I prob need bigger injectors as well, but I'm doing this first.
ID1000's on E85 btw.
I'll just add that I've also added a 150 amp alternator, 4ga charge wire to the rear mounted batt and 75A relays with 8ga wire to the pumps. My logs also showed poor system voltage.
Ron
Old Feb 13, 2017 | 01:50 PM
truckdoug's Avatar
wow thats some serious wire.
can I ask what pumps and fuel line diameter you're using?
Old Feb 13, 2017 | 04:13 PM
RonSSNova's Avatar
Big pump is fed with -10
The small pump will be fed with -8
Filter is a paper spin on 10 micron diesel type fed with now a -10 and a -8 from the fuel cell.
Feed and return are -8
Holley pumps
Old Feb 13, 2017 | 09:15 PM
Forcefed86's Avatar
I saw a spike when I ran a single 255 and had another come on in boost. Had mine set to come on at 1 psi. It did very little to my tune. Was using E85 so its pretty forgiving. I didn't even try/need to tune around the activation point.
Are you seeing a spike in pressure? I'm sure the closed loop fuel control would be able to adjust for it pretty easily?
Old Feb 13, 2017 | 09:35 PM
oscs's Avatar
I had two 4303's one would kick on at 15lbs. I didn't see any spikes but I had the big boy aeromotive regulator.
Old Feb 14, 2017 | 12:31 AM
RonSSNova's Avatar
I'm on the factory ECU, so no closed loop fuel control.
I just finished plumbing it, so it is untested at this point.
The pressure switch I bought has adjustment from 12-24 psi, I forgot about that when I wrote my post. So I guess the point is moot and I'll just have to find out!
I'm running the Holley regulator as well.
Ron
Old Feb 14, 2017 | 04:57 PM
oscs's Avatar
Ron
I would think a properly sized regulator to pump selection would keep the fuel pressure in line at all times.
Old Feb 14, 2017 | 06:19 PM
Beanslsxnova's Avatar
On my stock truck rails and regulator I have seen a spike from 54 to 90psi when my second 044 comes on. It stays there until I let off then returns to 54. This is on pump gas/meth
Old Feb 14, 2017 | 06:56 PM
RonSSNova's Avatar
I tuned a friends setup with two Bosch 044's on the factory corvette Reg setup and it was the same. It couldn't control the pressure of two pumps.
Old Feb 14, 2017 | 09:00 PM
Sleeperls's Avatar
I'm going to run.my single aem until I get used to it. Then run a double with 10an feed 8 return. Should be fine for my power goals
Old Feb 14, 2017 | 09:50 PM
ScottyBG's Avatar
I run 2 340 lph pumps with the second one on a Hobbs switch. I have 2 switches both a 7psi
and a 2psi. I bought them both just for tuning purposes, so I could turn the 2nd pump on at the correct point. I run out of pump about the 7psi point for the first pump by calculation but in practice I hit 7psi low enough in RPM there is no problem. I do get a slight increase in pressure for about 0.2 seconds. Bumps up about 10 psi, then bleeds off nearly instantly if your watching the needle. Really just a quick blip. The fuel pressure regulator is a mechanical device and it does have to react. It is however barely noticeable on the data log. It is so small I wouldn't worry about it. The AFR drops rich by about 0.1-0.2 for a small fraction of a second. The quality of the regulator I'm told is a factor, some regulators are "faster" than others. I just have an inexpensive Racetronix one and it works great.
Old Feb 14, 2017 | 11:45 PM
RonSSNova's Avatar
Thanks for the info Scotty. I think I'll be fine turning on the second at 15psi when the volume needed is pretty high.
I bet in fact that improving the charging system and wiring is going to help as well.
Eventually though, I'll need bigger injectors......
Old Feb 15, 2017 | 07:00 AM
oscs's Avatar
That's what I use to do. Never had issues.
Old Feb 15, 2017 | 10:09 AM
Forcefed86's Avatar
If you're trying to push small injectors it would probably be better to have a regulator that's overrun by the second pump. That way you can cruise around with standard pressure and when the second pump comes on you'll basically have larger injectors. Assuming you have enough pump, going from 50's to 90's+ pressure wise in boost would be a good thing. Esp. for those using 80lb injectors. Trigger the second pump early and then your entire positive KPA map would be pretty linear.
80lb injectors would effectively be 115lb injectors at 90psi.
