Huron speed turbo kit question
Old Mar 6, 2017 | 10:34 AM
LSXHawk's Avatar
Default Huron speed turbo kit question
I have the t4 keep ur ac kit from Huron speed. What issues will I have if I want to add a 88mm turbo?
Old Mar 6, 2017 | 01:50 PM
KCS's Avatar
KCS
Moderator
Have you asked Huron yet? I'm pretty sure a PT88 is one of the turbo options in their kits.
Old Mar 6, 2017 | 03:11 PM
LSXHawk's Avatar
Yeah I called and emailed them. All I got in return was a message basically saying they will be out until march 12. Figured I'd ask on here first. When I got the kit they said the 88mm with the ac would work. Either a pipe I got is wrong or something because the turbo is hitting the radiator.
Old Mar 6, 2017 | 06:41 PM
Black_Sunshine_99's Avatar
I had to slide my radiator forward a little with the T7875 on my V1 AC kit so if you have the same I'd imagine you'll need to move radiator forward some.
Old Mar 6, 2017 | 08:29 PM
KyleLanter's Avatar
I just put a s480 on my kit the radiator had to come forward some. Oddly though not because of the turbo but because the cold side pipe hit the drain petcock. Other than that the v2 kit works fine with a larger frame turbo
Old Mar 6, 2017 | 11:01 PM
LSXHawk's Avatar
Can unpost up pics to show how close urs is to the radiator?
