(Picture attached) Is this the correct routing of vacuum lines?
Old May 8, 2018 | 10:49 PM
Cory51191's Avatar
Originally Posted by BlwnLs1GTO
This is sketchy.
I've routed my manual boost controller like that and it was very inconsistent. I'd run the bottom port of the WG directly from the turbo, or, if you want a true manifold pressure reading, take it from there instead.
The way you have that plumbed now, your boost controller will be controlled backwards. meaning, you'll need it set it at "Max Pressure" to get the WG spring pressure with the lowest boost setting.
The best way to route that controller is to the top of the WG. Then, you can slightly adjust little by little from there without taking a risk of overboosting your engine.
I blew up my last motor on the dyno because my manual BC was plumbed this way. I should have ran it to the top of the WG instead.
The car has been delayed for a while. The fab shop had it for 10 months.. and I’ve been in flight school for the Army. The car is still in MA waiting for me to finish her up..
Anyways; my most recent image shows the correct way to install a manual boost controller (according to Tial and Hallman). The only thing you could do differently is use the intake manifold or intercooler plumbing as a source prior to the boost controller.
I have no idea what that first diagram is showing, besides how NOT to do it lol. I guess the vacuum tree thing just didn’t make sense to me.
