cam advice
Old Mar 14, 2017 | 07:33 PM
boostedstang's Avatar
Default cam advice
I've got a foxbody I'm putting a twin turbo set up on and was going to see if the cam I got would be good or look for dif one.
It's a 6.0 lq4.It has 317 ported heads with a btr cam adv dur 278 int 287 exh DUR@. 050 226 int 234 exh lobe sep 116.0 vavle lift .605 576,edelbrock pro x intake. I took it apart put new bearings, rings gapped for boost,good head gaskets and studs. It has a power glide with Trans brake and 1.82 first gear and 3.42 rear.Would like around 700 rwhp to 800 if possible.It will see alot more street time then strip.Im putting a set of precision 6262 t4 with 81 ar.Also was going to see the best route for the fuel system,and ecu was going with either holley hp or dominator.Any advice would be appreciated this is my first turbo build.Thanks for any help.
Old Mar 14, 2017 | 09:01 PM
scottywheels's Avatar
message martin smallwood or brian tooley
Old Mar 15, 2017 | 02:55 PM
Martin Smallwood's Avatar
Cam you currently have will be fine at 700-800rwhp.
Old Mar 15, 2017 | 03:06 PM
Thanks Martin was just trying to see cause it wasn't spec for my motor.
Old Mar 17, 2017 | 02:23 PM
00Wildcat's Avatar
The cam you have seems fine to me to 1100whp with the rest of the combination you have, with the right person pushing the buttons on the tune.
