CX Racing liquid ic pressure drop
on the IC subject, once i calibrated the pressure sensor it looks like the pressure drop wasnt as bad as i thought. i did order two k-type thermocouples that i will install at the in and out of the ic and get some data on that to post.
i had a smaller w/a ic with a banshee radiator and 3 gal tank on my s10 and that system couldnt keep up on the street so this time i have a bigger ic with no tank except a full size engine radiator and im very curious to see how it all works. If it ends up not being enough im probably just going to go with a big a/a
http://www.ebay.com/itm/New-Roush-Fo...5YxAE4&vxp=mtr
I would see 9F degree temp rise on a 2500-8500rpm 4th gear dyno pull. I ran a closed system with no ice and would only see IATs over 100F if I let the car heat soak and then beat on it.
please share your results, i plan to post up when my turbos land here in a couple days.
i think i could make these 72s do the work at the track but i want something funner driving around.
Seen 16-17psi so far, when the power comes on its pretty linear and just keeps pulling. Only revved it to 6800 so far. On 20-22 psi it should really move.
unfortunatly i also got a little greedy and careless and ventilated a piston. i have a 06 5.3 on the way so the plus side is i will have back to back data with nothing but stroke changed. im going to reuse the heads, cam, block, and everything else, the only thing changing is the rotating assm.
http://m.ebay.com/itm/151041847132
And it looks identical to the cooler you posted, and probably is the exact same one
I can only say the is no way you have that kind of pressure drop, zero
Unless you have a shop rag in there
My charge pipe goes all the way from the front of the car to the back, then forward again and I only have just over 1psi of drop from compressor to plenum at 7500rpm,20psi+
With 4lb springs I make 24psi of boost on 18psi dome
how big are your charge pipes?
thank you for the data, that is exactly the kind of feedback i was hoping for with this thread.
too much timing. made a couple minor goofs when moving my timing table and timing boost tables around.
Ah ok, good to hear
Charge pipe is 3"
I monitor pre and post cooler temps. Here is just water, it's hitting 22psi when it gets ramped in here
It will hold around 90 on a full track pass with ice
