Wastegate will not open *issue resolved* op is dumb.
I have a stock 5.3 with a 7875, and t56. No boost controller, just wastegate spring. I started with a tial knockoff 44mm wg. I was getting huge boost, and pulled the wg off the car to test with shop air. Sure enough, it opened right where it should at 10 psi. At the time I also had the boost reference at the manifold, teed off for the bov, and boost gauge. So I welded a fitting to the charge pipe right after the turbo, just to make sure that wasn't the issue. No change. I then took the wg off the car, to make sure that there wasn't something else weird going on. Drove the car with an open pipe, with no waste gate at all, and as one would expect, there was no boost created at all. I just went and picked up a tial mvr44 local, put it on, and there is no change. still mega boosting.
I am stumped. I cannot think of a reason why the wastegate will not open if it is seeing a good boost source, and has a reasonable spring inside.
