Cam for high compression
Old Apr 14, 2017 | 02:59 PM
headed-ws6's Avatar
Default Cam for high compression
I'm looking to switch cams so I can go boost. I milled my heads .035 on my G8 GT and now I have around an 11.1 compression and wont to run around 6-8 psi. Would like to get a cam that changes the dynamic compression. Just not sure where to look or who to go with. Thanks for any advise.
Old Apr 14, 2017 | 07:55 PM
truckdoug's Avatar
what cam do you have now? stock? I dont see any problem with 11:1 and 8psi on pump gas if you keep the timing on the soft side
but i doubt you'll stay at 8psi for long haha "just another pound or two, and then i'll chill out"
Old Apr 14, 2017 | 08:57 PM
JoeNova's Avatar
Restricted User
Get a cam with a little overlap. Nothing too extreme, though. Less than 5* of overlap @ .050" so it'll still be nice to drive.
Old Apr 15, 2017 | 07:09 PM
mkvamso's Avatar
my gto had an 11:1 ls2 with a stock camshaft, maggie overspun to 13-14 psi and a 50 shot of nitrous
91 pumpgas
conservative timing and a cold plug and itll be fine
