Procharger twin intercoolers - CRACKED!
Made a pressure regulator gauge rig to go between the air compressor and the intake system. Plugged up the outlet coupling from the supercharger and put an air fitting on the intake to the motor. Also put a fitting to the Big Red blow-off valve so it can stay shut under simulated boost.
Set the pressure regulator to 20 psi and open the valve and heard A LOT of air moving. Turns out both my intercoolers had cracked welds on the inlet side. System couldn't hold more that 10 psi.
Who knows how long this has been going on!
Haven't put the car back together yet, but I'm sure it will be nice to have the power back!
Had a hard time finding a 3" to 3 1/8" plug for the rubber coupling that attaches to the D1SC outlet so I had to use a $2 plastic cup they sold at the local hardware store. I thought it would get destroyed, but it held very well and then found its way into the family cup rotation!
While pressure testing the welded up intercoolers the next leak that presented itself was the oval'ed inlet to the Y pipe that feeds the front intercoolers. No matter how tight that t-clamp was it just wouldn't seal. Why would procharger put an oval'd pipe in a pressurized system?
It wasn't a showstopper kind of leak and the system held 20 psi fairly well. It's incredible how hard all the rubber hoses got under 20 psi.
Next comes the driving test.
The bypass not working doesn't make any difference.
If I pull the vacuum hose off my bypass the valve closes and stays that way until vacuum is reapplied. So the bypass not working would make a big difference in letting off the pressure in the system when the throttle blade closes ???
The intercooler maybe just broke from poor welding
Back in 2008 when the kit was first put on I got the car back and it didn't feel much faster at all. With no boost gauge I had no idea what was wrong. Took it back to the shop and it turned out the vacuum line they spliced the BOV into had a check valve on it so the BOV stayed open all the time. That was back when I didn't know squat about superchargers.
My guess would be a combination of weld quality and fatigue over 8 years of use. That aluminum plate is pretty darn thin too so there isn't much to weld together.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Little driving and update. Pictures below show data log before and after fixing the intercoolers. The pulley combo is 8.65/3.85 so the blower is spinning around 62k at 6800 RPM. This is with an air filter as well.
The car was making 10.9 psi with the leaking intercoolers and 16.7 psi after being fixed. Gained back almost 6 psi ! 16.7 is the most I've ever seen with this combo. Needless to say, the car feels so much better now.
