Looking for input on a boosted combo
Old Apr 26, 2017 | 10:27 PM
boostedchevyII's Avatar
Default Looking for input on a boosted combo
Hey all, im new to the forum and new to the ls world not new to high performance builds. I have decided to do a "streetable" ls turbo build and was looking for input on what exactly is my best bet to build. I have a modest budget and dont want to skimp out on the important things. I want to make power in the 13-1500 range on race gas and 20-25 psi of boost. I will be doing a fuel injected setup. I dont have any parts yet but am ready to start getting them. Any input would be greatly appreciated on what it will take to build this kinda motor. I have been looking at some AFR heads, possibly doing a 408 cubic inch motor. Im thinking i need to be somewhere in the 700 hp range before the boost. What do some of you guys think?
Old Apr 27, 2017 | 07:29 AM
lmt0705's Avatar
My 427 lsx made 576 on the engine dyno and will make in the 14-1500 rwhp range on the chassis dyno under boost, drives great the street. I think your trying to push a 4 bolt head block way too far IMO. Your going to want a center counterweight crank, really good set of rods too
Old Apr 27, 2017 | 07:54 AM
svslow's Avatar
700hp before boost? Going to be a pretty serious 408.
Old Apr 27, 2017 | 03:13 PM
yeah i planned on an lsx block and good rods for sure!
Old Apr 27, 2017 | 03:44 PM
blake b's Avatar
I have a 427 that made 714 on the engine dyno. My turbos are too small (EFR7670s) for the engine but I'm going to run them anyway. I figure a reliable broad powerband with 1000whp will make for one hell of a fun street car since it will be spending most of it's time in the lower and mid RPM ranges. I'll put bigger turbos on later if I need more HP.
When I mention to others the turbos are too small, many different people have pointed out it is no fun fixing broken stuff all the time especially since I am running a 6 spd in a heavy car.. If I break it, I'll go 4L80E and put some larger turbos on it and make 1300-1500whp. 1000-1100whp seems to be a good stopping point.
I'd go look at some engine builder sites as many have packages and see what is in them. When I was looking for 1500hp short block packages, the common things I saw across the board were:
LSX or DART SHP block
Callies Dragonslayer crank
Callies ultra I or H beam OR Oliver rods
Piston brands were all over the place
As far as turbos, I'm far from an expert (and only using the EFRs because I already had them), I'd contact bullseyepower or forcedinductions or many of the other turbo people. I think you are going to be looking at a 63-66mm wheel but check with them.
