Cruise AFR and timing
'55 Chevy with 6.0/4L80E
S480/1.32/96mm
Holley Dominator
Holley 120 lbs. inj
93 octane pump gas
Vic Jr and elbow
9" with 3.55 gear
28 inch tall tire
75 mph is about 2400 rpm with converter locked
I've gone as high as 45 degrees on timing at steady cruise just to see what it does and it's still there.
On idle it likes 13.8 AFR, I keep thinking that's too rich but it just doesn't like to idle good on anything leaner. Moving the idle timing around doesn't really change it much. IAC motor is at 10%-12% without the AC on so I'm good there.
At cruise it wants 14.0 and that just seems too rich, but that's what it wants. Plugs show rich as well. (TR6 gapped at .024)
Saturday I went to a rod run in Beaumont and I tried leaning out the cruise and it just didn't like it. I've tried from 14.5 to 15.5 and the leaner I go the worse it gets.
Bottom line is give it what it wants just like the old days tuning Holley carb before wide band O2 sensors.
I'm going to get my wife it drive so I can sit in the passenger seat and fine tune it. Now that I've decided to just let it be fat I'll experiment with some higher timing at part throttle cruise.
Doesn't seem to be much vacuum at part throttle cruise but that may just be normal for a turbo and this is my first. Around 55 kpa at cruise.
The fact that your cam has positive overlap has a much bigger effect.
I did do a compression check just to make sure and all were within 2 lbs. of each other.
Since I started this thread I made a good hard pass then pulled all the plugs and they were all clean except #8 which was just as black as it could be. The water/meth is what cleaned them up from my pass so I'm going to change the #8 coil and see if that makes a difference.
Weather is crappy right now with a Tropical Storm bearing down on us so it'll be a few days before I can test again but I'll come back and update.
