Does this look like spark blowout?
So... perhaps clutch slippage is causing this, or perhaps blowout?
I theorize that perhaps its the clutch slip unloading the motor/turbo, which changes the MAF readings (which changes the A/F readings).
I use EGT to help with the AFR requirement.
What are your EGT's ?
Lance
If my WB was off, then the dyno's WB would have to be off as well correct?
Where the issues were happening, the dyno A/F has me between 11.5 -12.5 A/F, while my WB showed 10.6-11.3 A/F. I expect the WB at the tailpipe to be leaner (typically 0.5 A/F leaner, but my cutouts were open for this run). You are implying that perhaps I am even richer than 10.6-11.3? I dont know if I buy that, but it is something to certainly consider. I will say that at idle/part throttle, the fuel trims from the NB readings align with my WB, so the WB would have to me malfunctioning at WOT only.
EDIT *** I have the AEM Failsafe WB*****
I created this pos t because of my research online that showed similar dyno graphs with spark blowout, so figured I'd ask. Clearly the clutch is slip is muddying the diagnosis up. I do appreciate everyone's input on this.
What is the sensor location, if before turbine, as the "read" IS effected by EMAP ?
You can "melt" a piston crown with too little Spark Advance AND too much Fuel.
That case is found by observing EGT.
I am able to "clean" a Hot Wire sensor by removing the duct, then to spray some CarbKleen.
MAKE SURE it's cool first, NOT with Key ON.
I have seen cases that allow a baffle to be installed in the air tube before the MAF, this will stop the air "spin".
Lance
Lance
WB is downstream from turbo in the DP, probably 40" away.
i am running 12 deg @ pk torque and 15 deg at peak power at 16psi.
Ill give the sensor a cleaning. I am gonna go back and look at old logs with the old clutch to see how the MAF readings were
therefore, even on smooth dyno graph I still see I have MAF fluctuations. While it didn't cause any issues before, if I want to address it in the future, I'll need to work on a flow straightener or go speed density as you mentioned.
Short term, I need to get more heat into this clutch and see if I can get it to fully grab.
my AFR does show a reaction (leaner) in the area of concern, just not substantially leaner.
