need a little help with boost issue
they dont. that used to be a very typical situation on turboed cars. boost would typically drop from 0.8 bar to 0.5 bar at redline. thats why they were so easy to tune. if you took them to 1.0 bar and kept it there you had a 0.5 bar difference.
The exhaust 'valve' of the wastagate has a face diameter that directly influences the applied force from exhaust gas. Larger faces of larger valves allow more of the exhaust gas to apply a force to the valve and open it. A gate can open based on exhaust gas pressure alone. Think about this- if you left the spring out of the gate and didn't connect it to anything, would it still open? Of course common sense tells you that the exhaust is going to open the gate, because there is no force coming down from above. The same thing happens when there is a spring holding it shut- but now you see that the spring force might be overcome by exhaust gas pressure. There are all kinds of calculations online about how much force a given size face wastegate valve would take vs spring pressure rates and so forth, if you are interested it should not be difficult to find.
And as others say, more often than not OEM will allow higher boost in mid range, tapering off at higher rpm. But as with everything...there are many many variables.
But as you're experiencing a drop at higher loads, you could reference close to the throttle but on the boost pipe side.
But ultimately if you have a lot of EGBP or some other build limitation, then it will need a different fix which could be a different plumbing configuration for the gate, or a programmable controller.
