Turbonetics please help!!
Old Jul 10, 2017 | 07:15 PM
garhar's Avatar
Default Turbonetics please help!!
I purchased and installed the Turbonetics CARB legal turbo kit on my 2012 Camaro SS and had a severe oil leak at the oil drain off the bottom of the turbo - the rubber gasket failed almost immediately after install - I had 2 of these rubber gaskets in the kit so I removed the turbo (hugh project) and installed the second rubber gasket which failed as quickly as the first one - Such a severe failure that it was a fire danger - The Turbo Heat Blanket was also soaked with oil to the point of a fire danger - I contacted Turbonetics immediately about my problem and was told that they replaced the original gasket with this rubber gasket because of problems and that I probably overtightened the rubber gasket and did not install lock tight on the bolt - I looked carefully looked thru the installation instructions and found no special torque requirements or lock tight on this rubber gasket and bolts and I asked for a new rubber gasket and Heat Blanket but was declined - Does anybody have a good contact at Turbonetics to get this resolved, I am not happy with their customer service with this problem?
Old Jul 10, 2017 | 10:29 PM
transam69230's Avatar
Dude.....Go to the parts store get some high temp RTV, I used copper looking stuff and fix it yourself.
Get rid of the gasket altogether. Clean both sides good with brake clean, apply and reinstall drain flange to the turbo.
Old Jul 11, 2017 | 05:36 PM
stevieturbo's Avatar
A rubber gasket for the oil drain ? That sounds all wrong.
Old Jul 11, 2017 | 05:39 PM
Black_Sunshine_99's Avatar
Mine came with a stamped exhaust mainfold style gasket...
I put a thin film of high temp RTV on it and its never...yeah I'm not falling into that trap.
Find a better gasket or no gasket and high temp RTV lol.
Old Jul 12, 2017 | 05:22 AM
LS1-IROC's Avatar
I've had good luck with Ultra Black RTV on my Turbonetics.
Old Jul 12, 2017 | 06:26 PM
Taxman20's Avatar
I used a gasket sealer from the dodge dealer. Its diesel exhaust gasket sealer. Super high temps and has worked great. Hard as hell to get the seal to break when you need to remove the fitting. I also used it on the flange and when removing the turbo had to hammer a gasket scraper/putty knife between the turbo and flange to break the seal.
