building boost on footbrake?
Here's an in car video. Skip to 30 seconds.
https://www.youtube.com/watch?v=OdSqiWthdkA
The chance to melt a Turbine Wheel is possible.
I suggest fitting an EGT Gauge just in front of the Snail.
When the AFR is correct, you WILL make more MAP.
Lance
Lance
Ok. Thanks. How lean is to lean ? I'm right at 12.8-13.0
i tried doing that method with my car but once i tried to pump the brakes it started to spin and drag the front tires. of course i was on the street.
Mine is set up on a button on the shifter. I have to release the brake and button at the same time as well. I had trouble with it my first outing last year and would hold the 2-step button through the 60', LOL. I have it down pretty good now though.
Same here 2 step button on a cord and had issues myself launching and letting go of button. Lol. To add to all this chaos I build boost in 2nd gear while holding 2 step button and mashing gas and brake. Have to release 2 step, brake , and bump into 1 st gear all at once. Lol. Let the minds be blown hahahaha
