4.8 stock bottom end 600hp
Old Aug 5, 2017 | 10:48 PM
4.8poweredsierra's Avatar
Default 4.8 stock bottom end 600hp
I have a 4.8 in a 04 sierra reg cab short bed. I took the motor apart last summer and cleaned up everything. While it was tore down I threw some 243 heads with some blue springs on it. Also put a boost cam with mid to high range power. I'm already in the works of getting a turbo, injectors,and fuel pump upgrade. I'm just wandering what kind of power this setup will yield and what else I would need to make around 600hp if what I have isn't enough. Thanks in advance open to anything I'm still learning myself
Old Aug 6, 2017 | 11:22 AM
ddnspider's Avatar
Are those spring capable of handling your boost cams lift? You'll need a decent amount of boost to make 600rwhp assuming through an auto on a 4.8, but a good turbo and time should get you there.
Old Aug 6, 2017 | 12:10 PM
67Firebird455's Avatar
I'd recommend more spring than that on that small motor. I have Comp 918s on my 317s with an LS6 cam in my Gen 3 4.8 (spun a bearing), and ran up to 17psi on 91 octane alone because of the low compression. It was probably only making 500rwhp, but a gen IV with pump/meth could easily break 600rwhp in the 20psi range if properly tuned, but I'd recommend more spring pressure, because these little 4.8s like to rev (mine loved 7200).
Old Aug 6, 2017 | 12:16 PM
Yea I'm going to put some.better ones on it. It starts floating valves at 6200 or a little higher. I was just going to try around 15 psi and see what that brings
Old Aug 6, 2017 | 12:37 PM
VTC_WS6's Avatar
On my previous Gen IV 4.8, I was making 760 on 16psi from a 78/76, granted that was through a M6, but with the right setup you can absolutely make good power. I've since gone to a Gen III (old one spun a bearing) and a TH400 so I'm sure i'm making a good bit less, but don't discredit the potential of the little 4.8, just have to make sure your setup is moving air!
Old Aug 6, 2017 | 04:35 PM
I have another question. I'm wanting a 76mm turbo but I'm wanting it to spoil up faster. Is there something to look for when buying a turbo to make it build.boost faster
Old Aug 6, 2017 | 05:08 PM
svslow's Avatar
Depends on the 76mm you are looking to get. That could be a $250 or a $4000 turbo.
