Feedback on my New Build PC'ed 370.
Old Aug 11, 2017 | 06:55 PM
89BANDIT's Avatar
Default Feedback on my New Build PC'ed 370.
Hey guys. Most questions have been asked and answered on here for years now. So what i'm asking is, I would like feedback from Anyone out there with a similar build. What HP and TQ there making. And what ET's there running. And from trial and error. What would YOU change, or add, or remove even. Car will be in my 1989 T/A WS6. Going away from the SBC route. Planning to make similar power. But be alot more Streetable with the LS. So here we go- LQ9 370ci, Need help choosing block, and all internals. TFS 235 heads, Procharger F1A-94, Built 4L80, Pro Torqe stall 3800-4200???, Holley Hi Ram intake, Prob going down to 345ish gears (have 373's now), Need help with internals, Cam, and fuel system. Looking to make 850-950RWHP. And run lower 9's. Maybe higher 8's if I set it up form the track. Car is rarely ever driven much. Just does a bit of Street Fighting here on Long Island. Light to Light, 1/8th mile type stuff. Love embarssing rich dudes n there Lambos and Ferrari's out here lol. As far as cam goes. Prob 620+ lift. I do want a chuggy, choppy loud cam. I know it will sound docile comapred to my SBC, and I dont drive the car often at all. So, NO it wont get old or obnoxious to me. CR ratio, want something that wont feel lazy out of boost. Some guys say 9.1, some say 10.1. So again, Questions are Internals, Cam, CR, Gears, Fuel system.
Will be 93oct + meth.
Thank all you LS Experts for you're Help.
And Do not hesitate to throw in anything else i'm sure i'm leaving out.
Old Aug 11, 2017 | 08:46 PM
silvea's Avatar
Cam should be custom designed by someone like ljms, cam motion, or vengeance. CR with 93+ meth I'd say go 9.3-9.5. Internals should be rods and pistons a factory crank should handle that no prob. Obviously arp everything and sruds where applicable. Your gear choice seems ok.
Old Aug 11, 2017 | 10:11 PM
CyberGrey Z28's Avatar
What's your cureent set-up and how much is it making now?
Old Aug 12, 2017 | 08:30 AM
89BANDIT's Avatar
Yes, was thinking custom cam from one of those places. Def ARP studs and everything. What can the stock crank rev to? Was thinking buying an already forged setup. But when I go to ATK's website (and others) they have about 20 diff 370's diff pistons, cranks ect..
^ Right now have a big cube SBC, Older Brodix heads, Built 700R4, 373 eaton 12 bolt, with a rebuilt and pullied up D-1sc. Never dynoed. Prob making around 750-800at the wheels. Car hold's it's own against anything I come across on the Street here. It's been kind of a Secret Combo though.
Would luv to get my AC back in the car right now.. And hear my Radio lol
Old Aug 12, 2017 | 01:10 PM
silvea's Avatar
Idk you will hear a bunch of different ideas but don't worry about revving it to the moon. A lot of big blocks don't rev THAT high and make big power. No reason you can't take a stock crank to 6750-7000rpm and adjust the pulley size on the blower to make boost sooner and spin less rpm. Will make your **** stay together a lot longer. Talk to whoever is going to do your cam and let them help you with a complete set up. It will also make their job easier since they will know exactly what you have. Doesn't mean you have to buy all the parts from them though. Just pick their brain for knowledge. Rick performance was very very helpful when I was buying parts for my 370
Old Aug 12, 2017 | 01:26 PM
89BANDIT's Avatar
^ Cool. So is there a consensus for LS Boosted cam guy on here?
What are the components on you're 370?
Old Aug 12, 2017 | 04:01 PM
neverstop's Avatar
i'm making 900whp through D1SC on a 427ci setup so somewhat different but on 91 ocatne with dual meth. I would say custom cam for sure and I went with 9.75:1 compression and working very well so far. really curious how the f1a94 works for you. seems like perfect for what you're looking for
that blower will make 1250+ hp so seems like kind of a shame to not put a good crank in there while you have it all apart. If it were me i'd probably go with 1/2' head studs too since its a 4 bolt setup but some may disagree.
Old Aug 12, 2017 | 04:06 PM
89BANDIT's Avatar
I know the heads come in 6 bolt. Cant you revise the block for 6 bolt heads?
I was thinking about the 427. But alot of $$$. Figure I can make similar power with the 370. neverstop, how much boost are you making?
Old Aug 13, 2017 | 09:35 AM
transam001's Avatar
i have a 370 with a s484 i know its turbo but i made 1064 wheel at 20 lbs ith full exhaust and a small intecooler. i have changed the set up now looking for 1300 wheel out of the 370. i have k1 crank, eagle rods ,wisco pistons. i only rev the car to 6700.
Old Aug 13, 2017 | 09:55 AM
89BANDIT's Avatar
^ What heads? Do you buy the motor built. Or have it done? What CR??
Old Aug 13, 2017 | 09:59 AM
transam001's Avatar
ported 317 heads. 10.1 cr, a shop here put the short block together. i am putting a dart ccw crank and wisco rods in it this winter before i turn it up much more. prob pushing the bottom end a bit. this was trough a th400 and a 9in also.
Old Aug 13, 2017 | 10:32 AM
89BANDIT's Avatar
^ Nice! So you're sticking with the 317's? That's Nice Power!! What Intake you Running? I'm still a bit torn between the LSX-R, and the Holley High Rise.
Old Aug 13, 2017 | 10:39 AM
transam001's Avatar
believe it or not i am running the holly mid ram. i wanted it to stay under the stock hood. i just put pro efi on the car and we put a 5" bumper exit exhaust and a huge a/a inter cooler. should prob pick up 100 hp at the same boost as last set up.
Old Aug 13, 2017 | 11:00 AM
89BANDIT's Avatar
WOW. I've been researching Intake's for hours now. You are Def leaving power on the table with the mid ram. You should go LSXR to keep stock hood. You will pick up 30-40Hp at least. From the back to back dyno comparisons Iv'e read lately. Car sounds Beasty though!
Check this out,
http://www.hotrod.com/articles/20-ls...ifolds-tested/
Old Aug 13, 2017 | 01:21 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
Sounds like a good combination. A question came up about 6 bolt options. ERL used to spot face the outside of the block and weld bosses to the outside. Then drill, then surface. I don't know if you have access to a mill, but it wouldn't need to be expensive to be effective.
Meth has a point where it doesn't like turning corners in the factory style intake manifold and mixture distribution is lacking. If that's how you want to fuel it, it does sound like a ram style intake with a better spray pattern would be safer at the expense of some torque. 3rd Gen TA's are so cool that I'd hesitate to go through the hood with a Hi-Ram too.
If you have any questions about the TFS 235's, let me know.
__________________
Old Aug 13, 2017 | 02:10 PM
transam001's Avatar
how much do you think a set of trickflow heads would benefit my combo. thanks .
i want to change the intake but my combo works so well that i kinda dont want to mess with it also.
Old Aug 13, 2017 | 02:27 PM
89BANDIT's Avatar
transam001, Did you read the Article I posted?
Old Aug 13, 2017 | 02:33 PM
transam001's Avatar
some i am in the process of reading it now. i have seen were they are modifying the high ram and making them fit under the stock hoods.
Old Aug 13, 2017 | 05:46 PM
LS1Tech Sponsor
Basically it will make the power like falling off a log. You're picking up 100 cfm of airflow...and quality airflow that works well with a 4.030 bore size.
You're going to find the less restriction = more power at less boost = lower IAT's.
__________________
Old Aug 14, 2017 | 11:25 AM
89BANDIT's Avatar
Couple TFS235 questions, They are Obv 6 bolt heads. Would that cause a problems mounting them on the 6.0 LQ9 block? I've seen them used on here by alot of guys.Just wondering if there are any obstacles. This is my first LS build. I'm VERY familiar with GEN1 SBC's even GEN2 LTX's. So i'm needing help with this build. Also can't figure out what cc size to go with.
How well does the Holley High Ram match up to the TFS 235's? Would Port/Gasket matching need to be done? Don't want there to be any walls.
