Eboost 2 users, I need some help with boost by gear
Old Aug 20, 2017 | 06:25 PM
RonSSNova's Avatar
Default Eboost 2 users, I need some help with boost by gear
Trying to set this thing up so I switch to a new boost group after I move the shifter out of first gear.
I can hook 15 psi, and want to crank up the boost after I shift.
If you have done this, let me know. I have questions.
Ron
Old Aug 20, 2017 | 07:13 PM
Game ova's Avatar
Ron
I have E boost2... but haven't used the feature. I'm pretty sure you have to install the optional switches for it to work.
Old Aug 20, 2017 | 08:26 PM
RonSSNova's Avatar
I did. Doesn't work
Old Aug 20, 2017 | 10:20 PM
RonSSNova's Avatar
I think I figured it out. I needed to navigate to switch logic and choose the one I'm using.
ill know next weekend I guess.
Old Aug 20, 2017 | 10:29 PM
slowlsx's Avatar
You definitely have to swap over. I have the eboost street which is fairly similar. On mine I have two options in the switch logic menu, originally I had it set to where I push the **** in on the controller and it switches between boost groups. I set up the green wire to my brake pedal so that first stage was only when brake was applied and it didn't work. Made the adjustment to the switch logic and boost worked like a charm.
Old Aug 20, 2017 | 10:44 PM
RonSSNova's Avatar
Very cool! Thanks for the reply.
