Most Efficient Turbo = Less Heat?
For example, some say a small turbo pushed hard will be inefficient and produce a lot of heat. Where a properly sized turbo at the same psi will create less heat. How is that so and is it due to the turbine size, compressor size, or both?
I'm putting together my first turbo build and Want to get more info before buying the turbo. Thanks!
What I don't get is how can some compressor wheels, at the same psi, have different charge temps?
a compressor outside it's efficiency range will heat the air it is compressing more than one that is operating in it's efficient airflow range.
