new best
Old Sep 4, 2017 | 10:59 AM
yenkomike's Avatar
Default new best
made some runs with my buddys Camaro. ran a best of 6.06 @114 and 9.35 @144 mph at 3550 race weight but it is about out of turbo/cam/and fuel system
car is backhalf 75 Camaro
5.3 2005 gen 4 engine with rings opened up. all stock except ls9 gaskets isky triple 12 cam/ springs and trunion upgrade.
running on e85 microsquirt ecu deka 80# injectors. borg 80/83 t4 turbo 1.25 housing.
400th 3600 converter.
32/14 slicks 3.73 gear.
it is running 50# base fuel pressure so we can go up a few lbs of pressure but its in the 1 teens for duty cycle so its about done there.
I think there is a 9 flat in it with a perfect run and a little more timing
I have to say deka 80s have went farther than I thought on e85.
Old Sep 4, 2017 | 12:34 PM
3 window's Avatar
Nice work Mike. How much boost?
Old Sep 4, 2017 | 04:46 PM
yenkomike's Avatar
thanks. 22 to 23 psi . timing is low like 11 or 12 degrees so we might add a little once the fuel is safe.
