Boost drop twin turbo
Old Sep 28, 2017 | 03:16 PM
Tknz's Avatar
Thanks Stevie, I think I'm getting close and I think they are sized wrong,
im seeing about 5psi back pressure, and when the gates open lose all spool, then boost comes back out the front, it happens at 7psi with 7 springs, 15 with 15 springs and 18 with 18 springs,
aside from being too big, I have a 6mm hose going straight to the wastegate, is this too big?
cheers Tom
Old Sep 28, 2017 | 03:30 PM
stevieturbo's Avatar
6mm is perfectly fine.
And as said before, the only way air can come out the front of the turbo is if there is compressor surge.
If the w/g opens....which of course they will do it will happen gradually in relation to load/boost and this will never cause boost to blow back out the compressor.
Old Sep 28, 2017 | 04:15 PM
Tknz's Avatar
Even with a big drop in back pressure? Would it not surge then is it had no back pressure and high boost ?
Old Sep 29, 2017 | 04:51 AM
I've no idea what you're talking about ?
Why would there be a big drop in backpressure, and do you have any logs showing this ?
And in an ideal world, you would have no backpressure.
Old Sep 30, 2017 | 02:32 PM
Tknz's Avatar
I only have 5-6psi pre turbine pressure with about 15psi boost,
Most things I read people are the other way with more pre turbine/lower boost.
Have sent the turbos back to the shop and he is changing the compressor wheel down to a 57mm and keep the 68turbine.
Can't see the back pressure gaining put hopefully stops the surge..
Thanks for your help stevie, hopefiully
Old Sep 30, 2017 | 03:13 PM
It really depends on many things, but yes that is pretty low, could just mean your exhaust/turbine is very efficient given the engine size.
Which it probably is simply because you've a lot of turbine for a relatively small engine.
On mine, most of the time I've a pressure ratio of EGBP:MAP of 0.5:1 so EGBP is almost always lower than boost pressure.
There is no real reason you want backpressure to rise, you want it as low as you can get it.
