Need Cam Recommendation for TT 416
Combo
LS3 Block and heads w/Ferrera inconel ex valves, no porting, trunion upgrade
ARP studs top and bottom
Mahle coated pistons 9.1:1
Lunati 4" stroke crank
60lb injectors
Aeromotive A1000 pump
H-Beam rods w/ARP bolts
Garrett T3 TO4E 60 Trim turbos
Turbonetics Evolution Gates
Turbonetics BOV
Stock LS3 intake and TB
Air to air intercooler
In a 2700lb sandrail with a 4 speed and 36" tall paddles. Want to run on 91 pump gas.
Appreciate it.
And not sure what real results you're seeking...when most people here only quote 1/4 mile times, which I dont think will be too relevant to a sandrail.
You could probably pick from 100 cams that would all perform very well for you.
